Amp mounting,
Discussion in 'Car Stereo Amplifiers' started by Eleu, Jan 11, 2009.
  1. Eleu
    Eleu Full Member
    Ive always been told not to mount to your box, any thoughts?
    i never do btw, i place them on the rear seats or under seats in cab, or fab a set in for them.
  2. skidmarks
    skidmarks Full Member
    iv only heard not to mount the amps to the vehicle. mount them to a base and then mount the bass to what ever? i dont see what would be the problem mounting to a box except if you take the amp off and dont plug the screw holes might effect the box air pressures? i like to use mounting spacers on my amps to keep them cooler, looks and temp
  3. Kvo_8
    Kvo_8 Full Member
    i hear its up to personal preference. i've always mounted my amp on top of my box
  4. Lazy Eye
    Lazy Eye Full Member
    You Shouldn't Mount The Amp To The Box Bc The Vibrations Will Fry THe Coils. It Even Says The Same Thing In The Manuels To Most Amps...
  5. Kvo_8
    Kvo_8 Full Member
    i've done it for the past 3 years now and nothing ever happened to any of my amps. so idk?
  6. pedro quiroga
    ive done it both ways, but then again i had one tough azz amp on there so it didnt hurt it one bit.
    i can see if the box resonates soo hard it would tear it up,but a solidly built box wont so it cant hurt it.
  7. DMP
    DMP Full Member
    Nothing wrong with mounting it to a box.
  8. Eleu
    Eleu Full Member
    thats exactly what i figured, massive amounts of vibrations have to be bad for any electronic equipment mount near the epicenter
  9. G3n3R@1
    G3n3R@1 Full Member
    Many of my friends mount their amps on their boxes and they're just fine. Of course each box was custom built by mwah and won't resonate to the point of vibrations.
  10. kingsuv
    kingsuv Full Member
    2 things to consider when mounting an amp to a box.
    1. Vibrations can kill amps. Not all amps. Depends on how they were assembled. Some builders glue and screw down stuff to help it from coming loose, others do not.
    2. makes it easier for someone to get more if your car is broken into. A smash and grab may just be the box and subs, but it will become box, subs and amps if it is mounted to the box.
  11. zanilth
    zanilth New Member
    I had always heard you didn't want to mount to the box due to vibrations as well, however if you go read a few websites (I found it on crutchfield) then it is fine. Usually the vibrations aren't bad enough on the actual box...You can expect more vibrations in various other places in the vehicle.
