Amp installation
Discussion in 'Car Stereo Amplifiers' started by Newtothegame23, Aug 10, 2010.
  1. Newtothegame23
    Newtothegame23 Full Member
    I Have a 1985Oldsmobile delta 88. I want to run my amo through the car and into the trunk. However I cant figure out how to get my Power cable from my hood, through the car, into the trunk. I've heard something about drilling a hole in the firewall. How can I do this safely? Is there any other way to avoid this obstacle
  2. Z400
    Z400 Full Member
    Yeah, run it through your drivers side window, leave the window cracked...
    LOL
  3. Newtothegame23
    LMAO!! ok thats a good one
  4. Ranger SVO
    Typically it is safe to drill a hole around where the main harness goes into the car from the engine compartment. There are many other safe places, just check both sides and make sure there is nothing in the way. Its really no big deal, just take your time and double check before drilling.
  5. Klinkster
    Klinkster Full Member
    Be sure to use an appropriate size rubber grommet in the hole you drill in the firewall before feeding your wires through it.
    A fresh hole will cut wires like butter.
  6. bigaudiofanatic
    bigaudiofanatic Full Member
    Take a look at the rubber grommets in your fire wall I usually splice a small hole in one of them that has a lot of extra room and run it threw that. Or even better a lot of civics I have done have a blank grommet with nothing in it take it out and run it threw that grommet after making a hole in it. Whatever you do make sure to protect your wire from sharp metal.
