amp help for my 2 pioneer spl 3000 subs
Discussion in 'Car Subwoofers' started by jayz85, Oct 2, 2007.
  1. jayz85
    jayz85 Full Member
    so I have 2 12" pioneer 3000 spl subs that are dual 2ohm in a ported box hooked up to a power tekniques 5000w mono amp and as of late the amp cant and wont power the subs... and reading on here I was seeing that the amp probably cant do the job... so I was looking into getting a jl audio 1000/1 amp or a kicker 1000/1 because they go for about 500 bucks on ebay... does anyone have any ideas for something better at that price these subs are in a 2002 bmw 330i with a 120 amp alt and I have a 5farad cap but that can be upgraded if needed... and help with how to wire the subs to certain amps would help too... thanks. I will probably buying anything I get on ebay if that helps...
  2. aznboi3644
    Are these your subs??
    Pioneer Electronics - Sound. Vision. Soul
    power tekniques is a really crappy brand...that amp prolly puts out aroun 500 clean watts...wayyy overrated
    My local shop is having a sale on this Pioneer amp for a little under 500 bucks...solid amp
    With a REAL amp not that PT amp...you'll prolly need another battery.
    have you upgraded your big three???? If not I'd highly suggest that....top of the list thing to do
  3. jmenace_thakidd
    jmenace_thakidd Full Member
    yea big three is a must even if not running alot of power i think becasue eventually everyone upgrades
    check out KLUV KUSTOMS
    another good choice for an amp SAZ 30000D a really good amp and you can get it for about 825 shipping included
    puts out about 3200 watts at 10.7 volts on a 1.33 ohm load so it should easily reach 4KW with a good elctrical system
  4. jayz85
    jayz85 Full Member
    yea those are my subs... I havent really upgraded much... what I have in the car is an alpine cda-9887 and mb quart components all around... my alternator is stock and battery is too all I got is a 5 farad cap... I know the electrical has to be upgraded but right now I have no amp so my subs are just sitting in the garage... I wish I could spend 900 dollars on an amp... but I cant. max I can spend is like 600.
  5. jayz85
    jayz85 Full Member
    those are the subs... the electrical will be updated as needed b/c im sure that 5farad cap wont hold up... my budget cant do for 825 dollars... something less sure... could any jl or kicker amp power these subs better than that pioneer amp?
  6. aznboi3644
    Elemental Designs has there Nine.1 amps on sale for 295 bucks
    Elemental Designs
    if you can give it good electrical it can put out up to 1600 watts rms...its not 2000 watts rms but for the price and quality it is a helluva deal.
    I have one...I love it
    what is your price range for a new amp??
  7. jmenace_thakidd
    yea i have heard nothing but good things about the nine.1 definately a solid choice if on a budget if you let us know ur budget im sure we can find something that will work for you
  8. jayz85
    jayz85 Full Member
    my budget is like 500-600 max for an amp or two that will make these subs actually hit hard. that elemental designs amp sounds great... two of those would do some damage... I have a bmw and the alt only puts out 120amps and high output alts are expensive for my car like 370 for one... so which would work better a new alt or an extra high amp battery? for now...
  9. aznboi3644
    Hell the Nine.1's are on sale...you could get two of them and strap them together...full tilt strapped they'll could put out about 3000 watts with good electrical.
    I'd say upgrade your big three with 0 gauge or bigger and add another BIG battery in the back.
    I have a 120 amp alt i believe and i'm sure I could run two Nine.1s strapped at 2 ohms with an extra big battery in the back
  10. jayz85
    jayz85 Full Member
    so two of the nine.1's would out do 2 kicker 1000.1 amps with my big battery in the back with 0 gauge wiring all around for power? because the nine.1 and kickers would be the same price.
  11. aznboi3644
    The Nine.1 amps would be better...they are strappable meaning you only have to adjust one amp and the other amp does the exact same thing so you don't have to gain match both amps.
    I'd take a Nine.1 over a Kicker 1000.1 any day
    Hifonics is overrated
    Dan...he has a final load of 2 ohms...either of those amps wouldn't push his subs at all
  12. danracer
    danracer Full Member
    ohh ok i though he had a final of 1 my bad lol and damn i waanted that hifonics for me lol but since its overrated ill go with the mtx(sorry for the lil thread hijack for a sec lol) anyways ill see if i find something for that ammount of price which i dont think i will...lol
  13. jayz85
    jayz85 Full Member
    alright so the nine.1's I know come out better than the kickers... but would one jl 1000.1 do anything?
  14. Jeffc879
    Jeffc879 Full Member
    dude get a nine.1! those amps are the **** and for 300 you cant beat it. if you wanna blow your subs from distortion buy one of those dirty kickers. JL is way over priced. eD is a perfect example of why JL is over priced. they have a sub that competes with the w7 and beats it in some cases, for 300 dollars.
  15. jayz85
    jayz85 Full Member
    well I had gotten a memphis 16-2000d and when I hooked it up... it powered up and then blew... so I got my money back because I bought it from a friend for 300 and change... so I got that pioneer premier 2000spl amp... the sub coils are wired in series and the subs are parallel to one another... so the wires coming from the amp... should be... how?
  16. danracer
    parallel...
  17. aznboi3644
    wire each subs coil in series then parallel the two subs together...then just wire it to the amp pos to pos and neg to neg
