amp for JL audio 12's
Discussion in 'Car Stereo Amplifiers' started by tippmann7, Jun 30, 2010.
  1. tippmann7
    tippmann7 Full Member
    just picked up 2 JL Audio subs, 12W0v2. $95 each and i had $100 gift card so i couldnt pass it up. Now i just need a new amp. The subs are rated at 300rms each so any recomendations?
    your budget?
  3. tippmann7
    id like to stay under $150 on the amp
  4. pedro quiroga
    audiopipe. will do rated power. just pick a small one.
  5. tippmann7
    heres what im still not sure on. if i get a mono block, would i want one with 600rms since it has 2 subs on one channel? would a 300rms mono block do the job?
  6. pedro quiroga
    yes a 300 rms amp will do the job too. you never need to run a sub right at its rms rating.
    not sure if this pertains here, but i have the box with my 8's in my house running on 70ish watts. it shakes the hell out of the house now......ON 70 WATTS! (even on low power in my truck...160 watts.... it had good loud enough bass to fill my needs.)
    if i were to give them the power they had in my truck i would be knocking more stuff off the walls in no time.
  7. tippmann7
    ok thank you. i appreciate the help
  8. tippmann7
  9. pedro quiroga
    what will you be wiring the subs too; 1 ohm or 4 ohm?
    the crunch will do 500 x1 @ 4 ohms mono. the mono rating of a 2ch amp is usually its 2 ohm stereo wattage. i.e.. 50 x2 @4Ω - 100 x2 @ 2Ω- 200 x 1 @ 4Ω mono.
    but the crunch has no bass remote and is not flexible; meaning if you want more power later on you can't rewire it like you can the AP800.
    for the extra money i would go for the AP.
    or for more power down the road and a little more than the AP you chose..
    http://cgi.ebay.com/AUDIOPIPE-1800-...Amplifiers&hash=item5193c1bedf#ht_3539wt_1139
  10. tippmann7
    think il go with the AP, @4ohms. you dont think the AP1800 will overpower the subs?
  11. pedro quiroga
    not at 4 ohms... no.
