Alpine SWR-T12
Discussion in 'Car Audio Talk Homepage News' started by Caraudiotalk, Oct 29, 2010.
    $319.00
    12" 1800W 4-Ohm Type-R Shallow-Mount Car Audio Subwoofer
    Power Handling:
    • 300-600W RMS
    • 1800W Peak Power
    Features:
    • Impedance: 4 Ohms
    • Aluminum woofer cone
    • Injection Molded Santoprene rubber surround
    • High-Amplitude Multi-Roll (HAMR) suspension results in the highest X-max and SPL output in its category
    • Thin design allows for installation in compact areas
    • FEA-Optimization allows for maximum linearity, greatly reduces distortion, and improves power handling and output
    • Vented voice coil heat sink, and airflow management system keeps subwoofer cool, while reducing distortion
    • 4" diameter single layer edge-wound ribbon wire voice coil
    • Unique spider and pass-through gap design, provide over 50mm of peak-to-peak excursion
    • Neodymium 35SH magnet structure
    • Frequency response: 26-200 Hz
    • Sensitivity: 84dB
