Alpine NVE-M300
Discussion in 'Car Audio Talk Homepage News' started by Caraudiotalk, Dec 7, 2010.
    $349.00
    GPS Navigation Add-On System for iXA-W404 and iXA407
    • Alpine NVE-M300 GPS Navigation System
    • Add-On GPS Navigation unit for use with select Alpine multimedia head units
    • Provides an easy-to-use user interface
    • Easy-to-Understand spoken driving instructions
    • Built-In 12-channel GPS receiver
    • Integrated SiRF Titan processor
    • Touch Panel Compatibility allows touch operation to be performed by directly touching the monitor when unit is connected to an Alpine touch panel-compatible monitor or AV Head Unit
    • OnPoint advanced GPS positioning uses satellite-linked GPS positioning data, gyro sensor technology to determine the vehicle's direction, and accelerometer technology to gauge the vehicle's speed for continuous coverage of your vehicles location
    • Built-In 4GB flash memory provides pre-loaded with maps of the United States, Canada, Puerto Rico, and the Virgin Island
    • Map data includes over 6 million Points of Interest (POIs)
    • Built-In USB 2.0 interface with included USB cable allows you to acquire map updated whenever they are available
    • Text-to-Speech provides turn-by-turn voice guidance keeping your eyes on the road at all times
    • Displays current, maximum, and average speed, driving time, idle time and overall time, right on the Alpine monitor
    • Displays the strength and status of the GPS signal and allows you to see how many satellites are locked into your position
    • Optional 2D or 3D map viewing
    • Highway exit screen allows you to view up to three of the next upcoming exits
    • Fully customizable settings allow you to choose from 8 color schemes for the maps, four menu colors (aqua, ruby, emerald, amber), and select from several icons to represent your vehicle on the map
    • Trail Dot feature will indicate on the monitor where you have traveled along your route
    • Dimensions: 1"D x 4-5/16"W x 3-5/16"H
    Compatible Head Units:
    • Alpine IXA-W404
    • Alpine iXA-W407
    • Alpine IVA-W505
    • Alpine IVA-D106
    • Alpine IVA-D310
    • Alpine IVA-D300
    • Alpine IVA-W205
    • Alpine IVA-W200
    • Alpine IVA-D105
    • IVA-W404
    • TME-M770
    Package Includes:
    • GPS Navigation System
    • 79" Power harness
    • GPS Antenna with attached 16.5' cable
    • 2 Dual-adhesive Velcro strips (1" x 2")
    • Waterproof antenna pad
    • 5 Self-adhesive cable clips
    • Self-adhesive antenna mounting plate (2-3/4" square)
    • 82" Alpine 13-pin RGB cable
    • 4 Self-tapping screws (each with flat and split lock washers)
    • 78" USB cable (with Type A USB on one end and mini-B USB 2.0 on other end)
    • Owner's Manual (on CD-ROM)
    • Owner's Manual System Requirements sheet
    • Quick Reference Guide
    • Guide for Installation and Connections
    • Important Installation Instructions for the NVE-M300
    • Customer Care registration card
