alpine amp tunning??
Discussion in 'Car Stereo Amplifiers' started by jam23, Jul 24, 2007.
  1. jam23
    jam23 New Member
    what is the best way to tune my amp and sub? i have a alpine CDA-9831 HU with a MRP-m450 runing one type-s 10", the amp has a adjustment for gain, bass EG, and LPF and my HU also has adjustments for bass level and LPF which is the best combination for my setup?
  2. TheViking
    Set the HU controls to flat...
    Play a favorite track, then turn the volume up to 3/4
    Set the x-over to about 100Hz, and adjust the gain on the amp to where the sub starts to sound "crappy" (clipping the amp) then back it off just a touch
    From here, adjust the x-over to a point that makes it sound good to your ear, might be anywhere from 50-120Hz depending on your style of sound. The bass boost on the amp should be used carefully. dont get carreid away with it! A little bit can go a long ways.
  3. pedro quiroga
    this man knows his stuff. do that and you'll be just fine.
  4. jam23
    jam23 New Member
    thanks guys
    so once i set the HU to "flat" i leave it that way for good and only adjust from the amp?
    ive been posting this topic on a few different sites for the past 2 days and you are the first person to offer any help
    ty
  5. pedro quiroga
    do you mean as far as level setting the bass?
    do that from the head unit.all songs are not recorded equal.
    i leave my radio's bass at any where from -10 to 0 boost.
    0 being as high as i go.on occasion i crank it to +6.
    but only once in a while.for fun.lol
  6. jam23
    jam23 New Member
    thanks again
    im going to leave my bass level on my HU at 0 like you said ill play around with it when i break my set up in
