Alphasonik?
Discussion in 'General Car Audio Discussions' started by speedracer008, Jun 7, 2007.
  1. speedracer008
    speedracer008 Full Member
    alphasonik car audio? ever heard of them? are they good?
    and...will the POWER ACOUSTIK OV1-2000D (OV12000D) MONO-Channel 2000W GOTHIC Series AMPLIFIER and KICKER 06S12L54 L5 12" 1200W SOLO-BARIC WOOFER work good together..and pound pretty hard?
    i can tell you the PA 3000 will pound the hell out of a 15in sub.actually 2 of them strapped together will.
    check this out.6 PA 3000d's on 3 Fi 15's
  3. pedro quiroga
    oh also i had a PA LT980 running an L5 10in at 8ohms and it did a really good joob at it.heres a pic.the other amp is the 4ch LT960
  4. speedracer008
  5. TheViking
    I didnt even know alphasonic was still around!!!!!
    Back in my day, they were average at best. they did nothing exceptional and nothing out of the ordinary, they were an asverage lower end amp. Of course like all others they claied to be the greatest thing since sliced bread on a stick.
    Dont know about them today, i would venture to guess they are still average and nothing too special about them. They worked and did fine back in the day....you got almost got what you paid for, at a slightly high price......
    Again, today (11 years later) i dont know.....just my 1 cent on it.
  6. speedracer008
    viking...does that power acustic amp n kicker sub look like a pretty good combo?
  7. TheViking
    I am sure it would do a great job...but its all in the install buddy....bottom line, especially the box
  8. speedracer008
    would the box that you can buy on millionbuy.com work alright for that sub?
  9. aznboi3644
    prefab boxes suck balls...i would give a 12L7 atleast 2.5 cu ft ported
    that alpha sub will NOT handle 900 watts rms...overrated, i've give it a good 600 watts and call it a day
  10. pedro quiroga
    yeah 900 watts of bass is ALOT.hell even 600 like azn said is alot.my kicker is now running on roughly 450 watts rms. and it hammers.i'm running a kicker box built for my sub.it peaked at 45 volts on my meter on music.now thats alot of juice. at 2ohm mono.
    they make this box for the 12 also.THAT would be the only prefab i would consider.
  11. pedro quiroga
    i was pushing it though.so i backed it off a tad.lol
  12. speedracer008
    the kicker L5 says its 4 ohms...that means i run it at 4 ohms right?
  13. G3n3R@1
    G3n3R@1 Full Member
    well its DUAL 4 ohm, meaning if its wired in parallel then the amp will see it as 2Ohms, if its in a series then the amp will see it as 8Ohms.
  14. pedro quiroga
    yes true.ive had it at 8 ohms and 2 ohm mono.and that sub sounded nice at both power levels.
    the PA amp was putting around220 watts @ 8ohms.
    the PG is doing 450 @ 2 ohms
