Alittle Help
Discussion in 'Car Stereo Amplifiers' started by DurangoJester, Apr 27, 2006.
  1. DurangoJester
    DurangoJester Full Member
    Hello,I'm new here and alittle new to the car stereo scene. Just need a "Q" answered if possable......Ok,To start i have a Kenwood 122(45x4)Head unit with 4 Audiobahn speakers(w/tweets)hooked to it......I have two Fusion 8" subs in a box that i need to hook up to it and was wondering what size amp i should use? They are: 200 watts (100 rms)
    Chameleon green poly injected cone
    1.5" Kapton single voice coil
    60 Oz magnet structure
    4 Ohm Impedance
    Free space resonance (Fs) 35hz
    Efficiency 89db
    Frequency response 30hz to 4.5 khz
    Mounting diameter (mm) 7.04" / 179 mm
    Mounting depth (mm) 3.46" / 88 mm :alien:
    I'm not looking to blow my windows out and loosen my bolts....Just inhance my music alittle. My audiobahns do have alittle bass in them already.
    Well,thanks and Have a great day!!
  2. CadillacETC1997
    get the kicker 250.2 125 watts for each speaker plenty of power
  3. DurangoJester
    Thanks....is it 125 rms or full watts each? @channel right?
  4. Hautewheeler
    Hautewheeler Full Member
  5. CadillacETC1997
    kicker underrates their amps and unlike most companys the power name of the amp (for example 200.2) does 100 watts rms x2 channels or 200 rms x1 channel. in answer to your question its rms and more than likely it prob it putting out close to 300 watts total power rms
  6. DurangoJester
    Thanks,Sounds like the 200.2 or 250.2 might be the way to go. Thinking about an MA Audio 400watt(100x2 @4ohm). Would love a Fusion amp to go with my Fusion subs but hard to find around here in Erie Pa.
  7. CadillacETC1997
    i have a kicker 350.2 running my kicker 3 way 6x9s and dammnnnn it sounds good
  8. DurangoJester
    thats kool. Thinking about getting everything set up this weekend if funds and time go right.
  9. DurangoJester
    Just thought i'd let you guys know i got an amp. Profile 2ch 600w. Thanks again.
