i cant seem to find out how much this amp puts out at 4 ohms bridged. its 350watts at 4ohmsx2 channels and 700watts at 2 ohmsx2 channels. anyone know?
Funny, i looked all around and this is all i could find out. Doesn't say what it will put out if bridged at 4ohms... APX1402 * 2 Channel MOSFET Power Amplifier * PWM Controlled DC to DC Switching Power Supply * 2 OHM Stable Stereo (4 OHM Bridged) * MAX Power (@2 OHM): 2 x 700W * RMS Power (@4 OHM): 2 x 350W * Built-in Variable Low Pass Filter: 50Hz - 250Hz * Built-in Variable High Pass Filter: 120Hz - 3KHz * Built-in Variable Bass Boost Control: 0 ~ +12dB * Line in / Line out RCA Jack * Bass Boost Control * LED Power Protection Indicators * Channel Separation: Better than 60dB * < 0.5% THD (4 OHM) * Signal to Noise Ratio > 95dB * Speaker Short and Thermal Protection Circuit * Dimensions: 10"(W) x 13.6"(L) x 1.9"(H)
4 ohm bridged should equal the 2 ohm stereo output. if it does what it says then figure on close to 1k..maybe.
