WASSSSSSSUP FELLAS GOTTA PROJECT !!!!!!!!!!!!!!!!!! WELL GOT A 1991 BLAZER THAT ME AND MY BROTHER-IN-LAW R GOING 2 WORK ON WELL WE HAVE BEEN TRYIN 2 FIGURE OUT HOW 2 BUILD AN ENCLOSER WE HAVE 3 DIRECTED AUDIO SX12D4 12'S DUAL 4 OHM WE DONT KNOW IF 2 GO PORTED OR SEALED POINT THEM UP OR DOWN OR TOWARD THE REAR DOOR WE WANT IT 2 HIT HARD AS HELL WELL WE HAVE 2 DIRECTED AUDIO 2400 WATT AMPS AN Y SUGGETIONS ANY THING WELL HELP DONT TRIP WE WILL REPESENT CARAUDIOTALK.COM TO THE FULLEST WE HAVE THIS IS THE SPACE WE HAVE 2 WORK WITH LENGTH-37.5" DEPTH-28.5" HEIGHT-17.5" HERE R THE SPEC FOR EVERYTHING *600 watts continuous, 1200 watts peak power handling *16mm Xmax (one-way linear excursion) *Optimized for small sealed enclosures *Reversible trim ring allows driver to be mounted facing either way with style *Proprietary die-cast aluminum baskets for rock solid assembly *Vented spider landing provides forced-air cooling for the 2.5" voice coil assembly *Wide nitrile butyl rubber surrounds allow more excursion at low frequency *One-piece frosted ultra-rigid polypropylene cones *Custom rubber magnet cover protects motor assembly *Nickel-plated spring-loaded speaker terminals Click Here for Complete Specs Model SX12D4 Size 12" Magnet 109 oz. Power Handling 600 watts RMS Power Peak 1200 Peak Impedance Dual 4 Ohm V.C. Freq. Resp. 25Hz - 2500Hz Efficiency 84dB (1W/1M) Fs/Hz 32 Re 7.8 Qts 0.62 Vas/liter/ft3 32.07/1.13 Xmax 16mm Depth 7 3/8" THE AMPS 1 ohm stable - Externally bridgeable with built-in gain sync - double the power! - Continuously variable 12 dB/octave low-pass crossover - Switchable 30Hz, 24 dB/octave subsonic filter - Built-in blue LED top panel illumination - External LED/Fan power jack - Thermal, DC offset, reverse polarity, over and under voltage, and short circuit protection - High speed MOSFET switching power supply - High current, high efficiency MOSFET outputs - Switchable 8 dB bass EQ - 180° phase invert switch - Remote subwoofer level control function Type: Class D Mono Maximum Power: 2400 Watts CEA Primary Power (power into 4 ohm, all channels driven, 14.4V supply 1% THD+N): 400W x 1 CEA S/N Ratio (referenced at 1 watt/4 ohm): 60dB CEA Additional Power (power into X ohm, all channels driven, 14.4V supply 1% THD+N): 1200W x 1 @ 1 ohm Frequency Response: 20 - 250Hz Damping Factor: >50 Input Sensitivity: 150mV to 7.5V Crossover Type: Variable 12dB low-pass Bass EQ: Yes 8dB Protection*: T,S,D,R,O,L Dimensions - inches (W x H x L): W:10-3/4 x H:2-1/2 x L:14-1/4 Metric - mm: W:273 x H:63.5 x L:360
subs up port back. you should be at 38 inches and some change wide. i roll in a 96 jimmy. how do you plan to wire 3 d4 ohm coils? 2 will get you a 1 ohm load. hmmm just figured it out you could do a 2.6 ohm load wiring them series/parallel. or .67 ohm, but i dont know that your amp will like that. can they be strapped together? if so then the 2.6 ohm load should work with them
