can i hook up 4 subs safely 2 an amp with the following specs?? 300 Watt 1 Channel Amplifier Built in variable low pass crossover High Level Input Variable Bass Boost 0 - 10dB Power/Protection LED RCA Line Inputs & Outputs Thermal/Short/Overload Protection Circuitry Adjustable Input Sensitivity Full MOSFET Circuitry
You can hook up 100 subs to your head unit and it will work safely...as long as the load doesn't exceeds the amps capabilities. Amp model must be posted unless this is a crappy Pyle amp and you don't wanna tell us what amp you really have...no point in hooking up 4 subs on "300 watts" anyhow...no point to me
