is 3 jl audio 12 w6v2's too much for elemntal designs nine 1?can you wire the 3 12 w6 to 1 ohm? so each could get 400rms?
are your subs DVC 4ohm or 2ohm? if they are dual 2ohm then you'll be able to either get: 1.34ohms or 3ohm or 12ohm. of course you are looking at the lowest possible so that would be a 1.34ohm load. If they are dual 4ohm then you'll be able to either get: 2.67ohms or 6ohms. recommendation: if you really want to do this then go with the 3 dual 2ohm subs. Can it handle it? it could but they may be a little underpowered but again the nine.1 is a good amp. Just curious, why go with the JL?
i edited my previous post, are your subs DVC 4ohm or 2ohm? if they are dual 2ohm then you'll be able to either get: 1.34ohms or 3ohm or 12ohm. of course you are looking at the lowest possible so that would be a 1.34ohm load. If they are dual 4ohm then you'll be able to either get: 2.67ohms or 6ohms. recommendation: if you really want to do this then go with the 3 dual 2ohm subs. Can it handle it? it could but they may be a little underpowered but again the nine.1 is a good amp. Just curious, why go with the JL?
so if they are dual 4 ohm you're going to have to look for a 2ohm stable amp that puts out 1,800 watts at 2ohms. what's your budget for an amp?
well if you have the JL then just use them. what amp do you have now? Alpine PDX-1.1000? you can strap those amps... You could get another one of those and stap the 2 together. that would give you 2k watts at 2ohms.
could it do that daily? here's some amps that are pretty cheap but good. http://cgi.ebay.com/POWER-ACOUSTIK-BAMF4000-1D-4000W-MONO-Amplifier-Amp_W0QQitemZ220300198789QQcmdZViewItemQQptZCar_Amplifiers?hash=item220300198789&_trksid=p3286.c0.m14&_trkparms=72%3A1234|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50 http://cgi.ebay.com/POWER-ACOUSTIK-BAMF-5500-1D-CLASS-D-MONO-AMPLIFIER-AMP_W0QQitemZ360131064607QQcmdZViewItemQQptZCar_Amplifiers?hash=item360131064607&_trksid=p3286.c0.m14&_trkparms=72%3A1234|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
