2 ohm vs. 4 ohm
Discussion in 'Car Subwoofers' started by rekkonda, Mar 15, 2010.
  1. rekkonda
    rekkonda Full Member
    whats the difference between a 2 ohm and a 4 ohm sub
  2. Kvo_8
    Kvo_8 Full Member
    different voice coil configuration...no real ups or downs of either, it really depends on what amp, how many speakers you want to use, etc.
  3. fstrfvo
    fstrfvo Full Member
    2 ohm will be less resistence and ask for more current usually resulting in more power to your speakers.
  4. Ghiti
    Ghiti Full Member
    less resistance=more current=more watts (compared to 4) remember to keep this in mind when getting any audio equipment, it can mess up your math if you don't watch the impedance on all components.
    also generally the lower ohm's are better equipment.
  5. DrazyHaze
    DrazyHaze Member
    What about 1 ohm? if i wire two subs down to 1 ohm.
    isnt that to supply a max amount of watts to two subs?
  6. jonnyv713
    Yes, but you want to make sure your amp is stable to 1 ohm.
  7. fstrfvo
    fstrfvo Full Member
    jonnys right, if you wire up subs at 1 ohm to an amp that is not stable to 1 ohm it will shut down and maybe cause damage. Also it will put more stress on your alternator and battery.
