/ Register
2 Ohm sub
Discussion in 'Car Subwoofers' started by MTX4Life, Apr 8, 2011.
  1. MTX4Life
    MTX4Life Full Member
    Is there any way to make a 2 ohm DVC sub woofer be seen as 2 ohms at the amp?..
    sorry .. no. 2 or 1 ohm with that sub.
  3. TheViking
    run it on just one channel of a 2 channel amp.....no other way
  4. steve
    steve Full Member
    The only way is to run one coil and thats not the way to go. just run a 4ohm load. In right encloser you'll be fine, but to get the max out of your amp you'll need a different sub.
  5. Korporat Avengr
    Korporat Avengr Full Member
    I do not really understand how ohms work. I have a 2 ohm Kicker sub, its a Kicker enclosure so it's pre-wired from the box terminals to the sub and it says 2 ohms by the terminals. Is this presented as 2 ohms to the amp?
