alright fellas i was going 2 insatll this MTX THUNDER 3202 http://www.sonicelectronix.com/item_9941_MTX+Audio+TA3202+Thunder+3202.html but was going 2 connect it 2 my 6x9 and 6x8's there infinty 2ohm so if i were to connect 2 2ohm 6x9 to each othe would i still get a 2ohm load or is it even possbile 2 use the amp for my mids and highs
wire them in series to get a 4 ohm load. if you do them parallel it will be 1 ohm stereo. or just hook it up to one set for a 2 ohm load to yield the max output of that amp.
