i might want to use 1 15" sub instead of two 12" subs i was wondering waht would be better i had this 15" in mind but is it anygood?Power Acoustik PW2-15M - 15" PW2 Series Subwoofer • 1300W Max • 550W RMS • Injection Molded Polypropylene Cone • Rubber Surround • CONEX spider - , Component Subwoofers, 15" Component Subwoofers - Sonic Electronix
What kind of budget do you have for single 15? What kind of amp do you have, or do you need an amp too? Kevin
thats quite a low budget.you'll also have to get a box. 250 will not be enough,but lets see what we can find....... single coil or duel coil?
CRUNCH PZI325.2 1200 WATT 1/2 CHANNEL CAR AMP NEW - (item 150145611308 end time Aug-02-07 00:55:10 PDT) this will work for a final 4 ohm load. in mono
INFINITY 311A CAR AUDIO AMPLIFIER MONO BLOCK BRAND NEW! - (item 300135082322 end time Aug-02-07 12:20:57 PDT)
