03 Hilux Single Cab Sub Box
Discussion in 'Subwoofer Box and Custom Fabrication' started by jakey, Jul 3, 2009.
  1. jakey
    jakey Full Member
    Hello all
    I have been browsing these forums for a little while and just decided to sign up.
    I want bass in my single cab Ute.
    I don't have much room at all but i am willing to build the box in between the seats and behind them.
    I can't fit 12 inch subs in between the seats.
    So i decided to go with two 10" inch subs or two 8" inch subs.
    After listening to a fair few brands ect i have decided i would go for two 10 inch Digital Design 1510's. But i am not sure if i will have enough room for two 10's so i was looking at two 8's the 8's will be Digital Design 1508's you can look at the specs below.
    http://www.ddaudio.com/dd/caraudio/09/woofer09_1500.asp
    I don't really have a price limit because i will build the box to suit the subs and save up for what subs i want.
    I have drawn a quick picture of the box i plan on making for the subs.
    What do you think?
    Thanks
  2. jakey
    jakey Full Member
    Change of plans i will be making a box to go behind both the seats and i will be putting one Kicker L7 12 inch sub in there running off a kicker 750.1 amp in a ported box.
    Box-
  3. pedro quiroga
    will you have enough space behind the seat for it ported? box looks good.
  4. jakey
    jakey Full Member
    Yeah i should gunna get as much space as i can. I went to a audio shop and they said it will fit.
  5. pedro quiroga
    cool. how much space will it end up with inside?
    my old L5 10 worked great in a .88cf box. and even better in a 2.0cf ported box.
  6. jakey
    jakey Full Member
    Im not sure exactly how much. I will be starting the box in the morning, just gunna get as much space as i can the audio installation bay said it can be done.
    Wonder what its going to sound like?
  7. jakey
    jakey Full Member
    Cant fit a 12" L7 will be putting in a single 10" L7 how do you think it will sound?
  8. pedro quiroga
    im sure it will sound good. how much depth for the sub do you have?
  9. jakey
    jakey Full Member
    As for depth i have just enough to fit the sub in there.
    I just am not sure what to run.
    I have worked out that i can fit the following:
    One 10" Kicker L7
    Model Solo-Baric L7 10
    Size (IN.,CM) 10, 25.4
    Impedance (OHMS) 2 or 4 DVC
    Max Rec Amplifier Power (WATTS PEAK/RMS)* 1200/600
    Sensitivity (dB 1w/1m) 86.8
    Frequency Response (Hz) 24-100
    Mounting Depth (IN.,CM) 6-1/4, 15.9
    Mounting Cutout, Square (IN.,CM) 9-5/16, 23.7
    Min Rec Sealed Box Volume (CU. FT., Liters) .66, 18.7
    Max Rec Sealed Box Volume (CU. FT., Liters) 1.0, 28.3
    Min Rec Vented Box Volume (CU. Ft., Liters)** 1.25, 35.4
    Max Rec Vented Box Volume (CU. Ft., Liters)** 2.25, 63.
    Or
    Two 8" Kicker L7's
    Model Solo-Baric L7 8
    Size (IN.,CM) 8, 20.32
    Max Rec Amplifier Power (WATTS PEAK/RMS)* 900/450
    Sensitivity (dB 1w/1m) 83.6
    Frequency Response (Hz) 28-100
    Mounting Depth (IN.,CM) 4-3/4, 12.1
    Mounting Cutout, Square (IN.,CM) 7-1/4, 18.4
    Min Rec Sealed Box Volume (CU. FT., Liters) .33, 9.4
    Max Rec Sealed Box Volume (CU. FT., Liters) .75, 21.2
    Min Rec Vented Box Volume (CU. Ft., Liters)** .66, 18.6
    Max Rec Vented Box Volume (CU. Ft., Liters)** 1.0, 28.3
    Box will be in a ported box about .66-1.0 CU. Ft
  10. pedro quiroga
    id do the 8's. they have more cone than a round 8 and can get nasty loud in the right box and wont need a ton of space.
  11. jakey
    jakey Full Member
    What do you more experienced people think?
    I want a **** load of bass. Not to fussy on SQ.
    I cant eithe fit...
    Two 8"Kicker L7
    One 10" Kicker L7
    One 10" Kicker L5
    What will give me the most bass?
  12. pedro quiroga
    you CAN or cant fit those?? your post says cant.
    if its "can fit" then do the 8's. they have more cone area than a round 8. 64c inches compared to 50c inchs of a round 8.
  13. aznboi3644
    I would go with the two DD 1508a's if you have the space for porting them
  14. jakey
    jakey Full Member
    Here is the measurements of the box i can build it can be ported or sealed.
  15. pedro quiroga
    damn metric system lol.
  16. jakey
    jakey Full Member
    oh lol so what do you think is best?
  17. pedro quiroga
    the DD 8's sound great.
  18. jakey
    jakey Full Member
    So you reckon the DD1508's will fit n sound the best?
    what about a the l7's?
  19. pedro quiroga
    both are good. it boils down to which will fit the best and which ones are in your price range.
  20. jakey
    jakey Full Member
    Ok i think im going to go with kicker but i do not know what will sound better? two 8s ported or one 10 ported
