I just cant get it
Discussion in 'Car Subwoofers' started by k.black, Oct 29, 2009.
  1. k.black
    k.black Full Member
    What would be the best set up for my f150 super crew 09? 2 10 inch subs and an amp
  2. Kvo_8
    Kvo_8 Full Member
    there is no best. there's what you want out of a system and what you want to spend. as long as you're happy with it man
  3. pedro quiroga
    very true. to me the best is the best that I can afford at the time.
    do some research. find out what you want you system for. be it SQ or flat out SPL. or street jammin.
  4. k.black
    k.black Full Member
    a little bit of both right now I have so much higs with jsut a ittle bass wanna change that
  5. jonnyv713
    jonnyv713 The Young Gun of CAT
    what is your budget? I have been looking at alot of JBL 10's for a little bandpass in the back of my car. I hear the JBL's sound good in a sealed enclosures too so maybe you should look into them.
    Here's a link for one and an amp
    http://www.sonicelectronix.com/item_13867_JBL+GTO1014D.html
    powered with this
    http://www.sonicelectronix.com/item_13494_MB+Quart+DSC+2150.html
    or
    http://www.sonicelectronix.com/item_11752_Crunch+P1400.2.html
    or
    http://www.sonicelectronix.com/item_10085_PowerBass+ASA-800.2.html
    those amps get more power as you go on. Folks over at ROE say that MB Quart is a badazz amp. they use it alot for highpower mids and highs. The Crunch is made by the same company but i have heard they dont do quite rated power, and the PB amp is a little too much power by like 25 watts but is actually probably your best bet. I advise the Power Bass
  6. bhawk93
    bhawk93 Full Member
